| Автор |
Съобщение |
Rusin Atanasov има опит
Регистриран на: Oct 20, 2005 Мнения: 320 Местожителство: Стара Загора
Пуснато на: Чет Авг 17, 2006 11:16 am Заглавие: SE Class A 3.5/7 W с един транзистор |
Привет,
рових се днес в диуаудио и попаднах на тази схема ето точният линк към темата за 7 ватовата версия http://www.diyaudio.com/forums/showthread.php?s=&threadid=66822&perpage=10&pagenumber=1
тук е 3,5 ватовата версия
http://www.diyaudio.com/forums/showthread.php?s=&threadid=73598
Всичко е много добре обяснено има си платка и снимки на готови проекти. Ето мнението на 1 потребител от там за звученето на подобни схемни решения
The serious amps:
-Hiraga Le Monster: very nice and strong sound, but nothing special, if not that: You can't believe how can this 8 Watt amp to be so strong!!
-JLH1969: this is realy a very good sounding amp! A refference amp for ever. Very musical sound, one of the best.
-ZEN "classic": nice and very pleasant sound for the ears, but the bass, dynamic, details, soundstage imagineing not so perfect than the ....... see later
-ZEN ZV4: nice and very strong and dynamic sound, but also not perfect like the......
-ZEN BALANCED 25Watt: nice and brutal strong dynamic and bass etc. sound! A bit "dark" or gloomy sound. I am afraid I prefer the 2nd harmonic distorsions more....
-Zen Lite: It is a realy nice sounding amp, almost perfect, but the details and the sound stage imagineing and the bass control are not so fine than the....... see later
-Aleph5: very nice tube like sound with brutal power and dynamic.
-SEWA V1: O.K. here comes the winner! Nice, soft, warm etc. sound, but the most important what makes this amp unambiguous better than the others are the very strong and realy(!) detailed, controled bass, mega-brutal dynamic, incredible fine micro details and excellent 3D sound stage. The music simply alive in the listening room!!!
I have never listened or felt such a good presence feeling!
В момента слушам JLH 1969 оригиналната схема с разделителният капацитет и крайни 2sc5200 - много съм доволен от към звук. Но мен ми допадна схемата с 1 транзистор и това ще бъде следващият ми проект
Последната промяна е направена от Rusin Atanasov на Чет Авг 17, 2006 2:13 pm; мнението е било променяно общо 2 пъти |
| Върнете се в началото |
Daniel Petrov BG Audio Team™
Пуснато на: Чет Авг 17, 2006 1:10 pm Заглавие: |
Усилване<1, реално около 0.9 - колкото е по стръмен транзистора, толкова коефициента е по близък до 1...
Минимум 7 волта изходно ниво от предампа и транзисторите мигом станаха 2.
Като искаш 1 транзисторен усилвател, пробвай да туриш генератор на ток в дрейна...т.е. ориентирай се примерно към Зен на Нелсън Пас...
http://www.passdiy.com/pdf/zenamp.pdf _________________ Inspiration Audio
IDS AG
Пуснато на: Чет Авг 17, 2006 2:15 pm Заглавие: |
Не, това е същата радост - сорсов повторител с коефициент близък до 1, но вместо сорсов резистор, има генератор на ток.
Пуснал съм ти линк към усилвателя на Пас с един транзистор - Зен.
Що не вземеш да прочетеш малко техническа литература с цел ограмотяване?
Не са ти ясни основните схеми на свързване на транзситорите, а искаш да правиш усилватели...
Много ще ти е по лесно, ако попрочетеш някоя такава книжка, в която са обяснени тия неща... _________________ Inspiration Audio
IDS AG
Пуснато на: Вто Сеп 12, 2006 11:43 am Заглавие: |
Оживих въпросната схема в насипно състояние. На калпави говорители вързани серийно свирна добре и с достатъчно чуваемо ниво. На първо слушане не забелязах изкривявания. На входа има сигнал директно от сиди плеар. Може би мощноста е около 1 Ват /по малко естествено/. Захранването ми е по-ниско от препоръчаното +22В и е +19в. Ограничен от към захранване и временно ползвам такова от друг усилвател, който е също клас А.
При първоначално пускане на схемата тока на покой нараства плавно от 0 до 1,80А.
Това нормално ли е ?
До пълно загряване предполагам ще се покачи още. Тук има малко снимки
http://store2.data.bg/rusin/OTA%203.5w%20Pure%20Class%20A/ |
D.Kolev BG Audio Team™
Регистриран на: Aug 10, 2004 Мнения: 1467 Местожителство: В.Търново
Пуснато на: Вто Сеп 12, 2006 1:24 pm Заглавие: |
1.захранването е много важно
2.без стъпало което да усилва по напрежение не го чакай да работи .
довечера ще пусна едно по-нестандартно решение с 2 транзистора , което се надявам да доразвием във форума  |
Пуснато на: Нед Юни 08, 2008 1:24 am Заглавие: |
След толкова време усилвателя ми е вече готов. Конструкцията е дуал моно поместен в кутия от дърво. Захранването е изпълнено с два отделни 230ватови мрежови трафа със собствени мрежви филтри.
Крайното стъпало:
 _________________ Made in home!
www.opelclub-bg.com/forum
Последната промяна е направена от Rusin Atanasov на Нед Юни 08, 2008 9:55 am; мнението е било променяно общо 1 път |
radev има опит
Регистриран на: Oct 13, 2007 Мнения: 163 Местожителство: София
Пуснато на: Нед Юни 08, 2008 8:43 am Заглавие: |
Много добра изработка,поздравления.А какво си закачил отпред за да повдигнеш нивото,че ме заинтригува  |
Пуснато на: Нед Юни 08, 2008 9:47 am Заглавие: |
Отпред имаше лампи-но все не мога да ги съчетая с ампа за да свирне всичко хубаво. Опитите продължават все още а до тогава го слушам на чисто.
Ето снимките:
Симулация на двустъпално свързване:
Сим на мю фолуер все още не реален:
Симулация на аноден повторител все още не съм го пробвал с изправено отопление. Изправеното отопление го правя с отки диоди в схема Гретц и филтрирам с 2х4700 мФ Нипон-Хемикон шунтирани с по един неполявен полиестерен следва 7805 с два диода на маса за да изавди на изхода си 6,4В
Изглед на прашната опитна постановка.....повече приличаща на бомбардировка
и шасито с паяжината кабели:
Ползвам симулацията само за да настроя грубо режима и да видя чиста синусоида а някъде ползвам wav файл за тест. Ползваните лампи от мен са 6н2п, 6н1п /много красиво свети може би най красиво от всичките изброени/, 6н23п /фаворит за мен/, есс85 Тесла, рсс88 Тесла,
е88сс Тунгсрам е есс88 Тунгсрам. Преда е както крайното стъпало с два отделни трафа. _________________ Made in home!
www.opelclub-bg.com/forum |
ivodjima чете и пита
Регистриран на: Feb 14, 2008 Мнения: 122 Местожителство: габрово
Пуснато на: Нед Юни 08, 2008 7:46 pm Заглавие: |
| Здравей, много ми хареса - поздравявам те за ентусиазма и творчеството.Успех |
