www.bgaudio.org :: Преглед на тема - Продавам Тechnics RS-B100 dbx 3 Head Deck
Този форум е заключен - не можете да пускате теми, да отговаряте или да променяте мнения   Тази тема е заключена - не можеш да отговаряте или да променяте мнения    www.bgaudio.org Форуми -> ПРОДАЖБИ
Roojo
Регистриран на: Dec 27, 2006
Местожителство: Габрово
МнениеПуснато на: Сря Апр 29, 2009 10:04 pm    Заглавие: Продавам Тechnics RS-B100 dbx 3 Head Deck Отговорете с цитат
Един от най-добрите и редки модели на фирмата.
Лицев панел и техническо състояние - без забележки.
По капака има нормални следи от експлоатация.
Цена - 280 лв.
Track System: 4-track 2-channel stereo recording and playback
Tape Speed: 4.8cm/s
Wow and Flutter: 0.022% (WRMS); ±0.038% (DIN)
Frequency Response
Metal tape: 15~25,000 Hz; 20~24,000 Hz (DIN); 20~23,000 Hz ±3 dB
CrO2 tape: 15~23,000 Hz; 20~22,000 Hz (DIN); 20~21,000 Hz ±3 dB
Normal tape: 15~21,000 Hz; 20~20,000 Hz (DIN); 20~19,000 Hz ±3 dB
Dynamic Range: 110 dB (at 1 kHz) with dbx in
Max. Input Level Improvement: 10 dB or more improved with dbx in (at 1 kHz)
Signal-to-noise Ratio
dbx in; 92 dB (A weighted)
Dolby C NR in: 78 dB (CCIR)
Dolby B NR in: 70 dB (CCIR)
NR out: 60 dB (A weighted)
(Signal level = max. input level, CrO2 type tape)
Fast Forward and Rewind Time: Approx. 90 seconds with C-60 cassette tape
Inputs: Line sensitivity 60 mV, input impedance 47 kΩ or more
Outputs: Line output level 700 mV, output impedance 820Ω or less
Headphones: output level 125 mV (at 8Ω) applicable headphone impedance 8Ω - 600Ω
Bias Frequency: 105 kHz
Heads
3x head system
2x AX head for rec/playback
1x double-gap sendust head for erasure
Motor
1x quartz locked D.D. motor for capstan drive
1x for reel table drive
1x for mechanical drive
Power Requirements: 220/240 V, 50-60 Hz
Power Consumption: 35 W
Dimensions: 43x9.8x27.3 cm
Weight: 5.6 kg
http://picasaweb.google.com/lh/photo/LSR-xGIJk7KkSyeFhG1eJg?feat=directlink
http://picasaweb.google.com/lh/photo/SIZo7Mr7qe6BcoEARY9Y9g?feat=directlink
http://picasaweb.google.com/lh/photo/5mxklZl88eUCdNxhoDsBIQ?feat=directlink
http://picasaweb.google.com/lh/photo/oEUmCufa4ua7Yc-s47bhKQ?feat=directlink
http://picasaweb.google.com/lh/photo/SjL3HZxE5WMA-fZUF4TvVg?feat=directlink
http://picasaweb.google.com/lh/photo/09sm45BmGDNm-zeuR5ptyA?feat=directlink
http://picasaweb.google.com/lh/photo/NWUm_sUYrodTtsouk8z5CA?feat=directlink
http://picasaweb.google.com/lh/photo/ldHpggcRY3zGqWY5QKc61A?feat=directlink
http://picasaweb.google.com/lh/photo/r7-BBS7VDFqnIaGQiOkvLg?feat=directlink
http://picasaweb.google.com/lh/photo/Kqp0jFu_PoLd7g3nXlrKzQ?feat=directlink
Росен Христов
тел.0887255757
balkan_gb@abv.bg
Този форум е заключен - не можете да пускате теми, да отговаряте или да променяте мнения   Тази тема е заключена - не можеш да отговаряте или да променяте мнения    www.bgaudio.org Форуми -> ПРОДАЖБИ Часовете са според зоната GMT + 2 Часа
